Hello
I have a Lupine Betty Pro which I bought in 2012. I am wondering if the Heavy Duty Stirnband shown here (https://www.lupine.de/produkte/zubehoer ... -stirnband) will fit to this lamp? Alternatively, are there any other Stirnband I could use for this lamp?
Please reply in German if you like, as I am capable of reading it.
Thanks in advance,
Øystein Sørensen,
Norway
Heavy Duty Stirnband for Lupine Betty from 2012
oystein_sorensen
montebianco
Re: Heavy Duty Stirnband for Lupine Betty from 2012
Hej Øystein,
the correct Heavy Duty Headband for your Betty should be this one - although it says "Wilma" in the title, it is compatible to all lamps utilizing the old O-ring fastening (see compatibility list at the bottom).
Alternatively, if you do not really need the HD headband, you could also use the standard one with O-ring fastening.
Hope this helps.
montebianco
Hope this helps.
montebianco
