Preview on new website online
Read more about the latest developments
Moderator: calle
Beitragvon Stefan » 06.10.2012, 14:51
Just follow this link to get to the 2013 line of products.
http://www.lupine2013.de
wegomyway
STVO SL-A
Re: Preview on new website online
Beitragvon wegomyway » 06.10.2012, 16:52
does not, because invites not
mit bing-translator gemacht :mrgreen:
Sven
Beitragvon Sven » 06.10.2012, 23:55
http://www.lupine2013.de/english
this link should lead to the English side.
*Updated*
Zuletzt geändert von Sven am 12.10.2012, 18:59, insgesamt 1-mal geändert.
Beitragvon Stefan » 12.10.2012, 18:27
We soon will update the existing preview page.
In development: Specifications, more Betty R pictures, beam comparison
Rotor
Beitragvon Rotor » 15.10.2012, 20:14
I’m not sure what actually will be updated… design or lumens samples will be changed?
In the moment Betty on 900 lumens is noticeable lower than Piko on 900 lumens!?
I have opened these samples in two different tabs and switched faster between them. It is obviously that between Betty and Piko there is a big difference on 900 lumens setting (advantage for Piko). Yes I know for the different lenses (angles), but I think that this is not enough for this effect.
PS:
I have not noticed the "Lighttest" functionality. That is grate and more convenient.
Zuletzt geändert von Rotor am 19.10.2012, 16:18, insgesamt 1-mal geändert.
Rotor
Beitragvon Rotor » 19.10.2012, 16:14
Any comments about my previous post? Do I only see that strangeness?
It looks like the lumens do not matter. Only watts relates to the light intensity.
If I’m asking for that into the wrong topic please told me.
Arsène Lupine
Beitragvon Arsène Lupine » 19.10.2012, 18:03
It's true what you say, but on the other hand: so what?
Maybe it is also just a matter of unprecise numbers in the lumens, don't know if all these steps have been measured or it is kind of a calculated value.
Piko at 13W is at max and so focused/set up on best throw in the width I guess, while the 8W of the Betty R is just an intermediary step and maybe focused on better illumination in the near field, assuming that if you want a better throw in the width you would switch up the level. Even the 16W Betty R picture shows a lesser throw in the width than the Piko at 13W. It is also a question of the beam pattern, maybe on the Betty R there are different outputs at the single 9 LEDs, depending from the level chosen.
Piko on 7W looks pretty equivalent to Betty R on 8W and indeed you can see the Betty R has a plus of illumination in the central spot on this level compared to the Piko.
I surely wouldn't base a purchase decision on such a comparison between one lamp at max. compared to another in an intermediary step.
regards
Rotor
Beitragvon Rotor » 24.10.2012, 12:13
Thank you for your answer Arsene Lupine :) It makes sense, but I’m not sure that it is absolutely true. The focus of any lens doesn’t depend from the quantity of light passed through it (but may be the source management affects it). After many time in contemplation :), my conclusion is that the Betty/Wilma stand is a little bit tilt to the ground in relation to the Piko’s one. You paid my attention to the over burned spots in front of the lights and I think that this effect is actualy caused from a little stand tilt.
Regards :)
Zurück zu „Lupine News“
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 1 Gast
